small oil leak
Old 08-22-2005, 09:28 PM
94_CRVtec's Avatar
94_CRVtec has disabled reputation
Default small oil leak
i have a b16 in my teg, and i am getting a little bit of an oil leak and im not sure where it is leaking from. the oil looks like it is comming from between the head and the block under the vtec selinoid but im not sure it also may be driping from somewhere. if anyone else has had this problem and might have some advice to where it might be comming from i would like the help
94_CRVtec is offline
Old 08-22-2005, 09:38 PM
Die reinste Bösen.
gear's Avatar
Default Re: small oil leak
id bet its the cam seal. those bitches go bad all the time. right behind the vtec selenoid there should be a black round 'plug'. look towards the bottom side to see if its leaking. Honda made a revised version of their cam seal with a little rubber o ring.... it replaces the old style and works well.
gear is offline
Old 08-23-2005, 09:47 AM
I heart honda
Wadman85's Avatar
Wadman85 is an unknown quantity at this point
is it gettin on the front part of ur motor?
Wadman85 is offline
Old 08-23-2005, 10:15 AM
94_CRVtec's Avatar
yeah a little bit
Old 08-23-2005, 12:25 PM
Asshole Supreme
S dot Camp's Avatar
Not to be super technical but the proper name is the cam end plug. The cam seal(s) are on the timing belt side of the motor.
S dot Camp is offline
Old 08-23-2005, 06:40 PM
CRX
CUMNURI
CRX's Avatar
CRX is an unknown quantity at this point
A new seal is like $10, quit being cheap. Or just stop by and we will figure it out.
CRX is offline
Old 08-24-2005, 02:32 PM
94_CRVtec's Avatar
we need to hit up sume junk yards this weekend
slowgsx95
03-23-2009 07:12 PM
SlowLS
12-16-2007 04:30 PM
97gsT01gsR
07-10-2006 10:00 AM
sebassttiann
12-12-2005 10:53 AM
Quick Reply: small oil leak
