b16a low 13's to high 12's
Originally posted by DoC-JoneS
new ignition - MSD
new ignition - MSD
conclusion....you dont need aftermarket stuff just because its aftermarket
Originally posted by dbprobe
This thread is getting off subject.
I just need some input on what mods it will take to get a b16a into the 13's-12's in a hf CRX. What kind of mods what brands all the details.
all motor
all motor
Originally posted by _burn_
why is there so much hype about ignition. inlinepro cars in northern va are running fast as hell on stock honda ignition. erick aguilar is running stock honda ignition....(and hes the fastest)
Good point,,but aftermarket is more reliable I think than a stock ignition....I would think
ls block with internals....point blank.
all motor
all motor
you missed the part where it says b16
well good luck on making power bud....we saw a 201 horsepower b16 crx run side by side with brutl. (mid 13's) and that engine has a fark load of work time and elbow grease into it.
for real......if you realistically want to hit 12's (without spending a gazillion dollars) go bigger. ide much rather work with a gsr or ls
honda ignition is fine btw....
yeah while oyu can run stock ignition, he sounds liek eh wants to build it up and a new aftermarket ignition system is def a good mod. cars run turbo's on stock internals too, doesn't mean they're good.
the main reason why the b16 sucks to go all motor, is the block dosent have enough oil squirters to go that high of a compression or a real high redline, you really need to get yourself a ls block or any b18 block of some sort
