b16a low 13's to high 12's
well i was gonna make a new thread about the same thing, but since this is here let me ask a question. If i get a B16A would i have to upgrade my rods if i went with the Crower 64302 (stage 2)Grind, chiped ecu for a 4200 vtec and 8700 limit, headers, intake, exhaust, blaster ss coil, FPR? Would really appreciate the input if yall have any.
Originally posted by Iceman
wELL heres my list:
TODA stroker kit 1.6 to 1.8/9
Crower rods, Toda pistons 12:5.1, Toda Spec B Cams & Valve sping & retainer kit, Bullet sleeves, Mugen head gasket, intake Type R Manifold, Ericks racing 70mm throttle body, port & polish head, DC 4-1 Headers, AEM V2 intake, Pulley kit, Tanabe racing Med. exhaust, Mugen ECU, Apexi VAFC, Powercore racing Cat, and a full MSD ignition setup, RC 310-340 injectors, AEM fuel rail,AEM fuel regulater. And I think thats it.
wELL heres my list:
sounds a good list from here...
wELL heres my list:
wELL heres my list:
that would be awesome if toda made 12.5:1 pistons for a b16 but they dont...biggest toda pistons you can run in a b16 is the 82mm which would give you a cr= 11:9 you could use a mugen headgasket or spoom and get to 12.2 but thats about it..
but too make it fast ls/vtec slicks stock jdm itr internals low 13's high 12's
Originally posted by SignfcntOthr
A lot of money, patience, and slicks would be my guess.
EDIT: Maybe not A LOT of money...but it wouldn't hurt.
in md they charge 1100 at the shop we go thru since you will need it bored and honed out..if i go through my friends acura its 500 but no boring..but the shop in md gives you brand new bearings which is also money..im not sure about acura
whatever you get itr pistons/ rings is on your own, i got my shit for 700..jdm itr fuel rail, injectors, flywheel,pistons,cams/ctr intake cam,valvesprings,retainers, valves also with mugen headgasket
i also paid 200 for jdm itr rods
ATM-22401 AutoMeter 2 1-16" Triple Full Pillar Gauge Pod 1988-91 Honda Civic $61.95 $61.95
ATM-4899 AutoMeter 5" Carbon Fiber 10,000 RPM Monster Tach With Shift Light $244.95 $244.95
ATM-6153 AutoMeter 2 1/16" Cobalt Oil Pressure Gauge 0-100PSI Electric $194.95 $194.95
ATM-6155 AutoMeter 2 1/16" Cobalt Water Temperature Gauge 140°-280°F Electric $126.95 $126.95
ATM-6175 AutoMeter 2 1/16" Cobalt Air Fuel Ratio Gauge Electric $69.95 $69.95
B-M-45074 B&M Pro Edge Shifter 88-00 Honda Civic/CRX, 93-97 Del Sol, 90-00 Acura Integra $139.95 $139.95
B-M-80746 B&M Universal Billet Look Aluminum Shift Knob $29.95 $29.95
BBK-1547 BBK 70MM High Performance Throttle Body, Satin Finish 1990-02 Honda-Acura 1.6L, 1.8L $369.95 $369.95
CCA-57200 Comp Cams Honda B-Series Camshafts, VTec Duration 250in./250ex. @.050", 214 @.050" Pri. Intake/Exhaust, 198 @.050" Sec. Intake/Exhaust $499.95 $499.95
EAG-81003 3.031-1.6L-5.290-Dome-SRP-10.6-10.4-5.7cc $1749.95 $1749.95
HED-37044 Hedman Chikara Header 1 5/8" | 1996-00 1.6L Honda Civic $259.95 $259.95
MAN-26100 Manley Valve Spring and Retainer Kit For B Series V-Tec $414.95 $414.95
MSD-6420 MSD 6AL Ignition System with Soft Touch Rev Control $194.95 $194.95
MSD-8291 MSD Distributor Cap, Mod. Honda Civic 1.5-6L w-VTech $38.95 $38.95
PSL-304 Power Slot Front Brake Rotor 1986-89 Integra | 1988-89 Civic, CRX DX|SI | 1990-91 CRX SI $69.95 $139.90
RDL-5W30CSE Redline 5W30 Synthetic Motor Oil (Case) $89.95 $89.95
RDL-WW Redline Water Wetter $8.50 $8.50
TAY-98071 Taylor Thunder Volt 50 Wire Set
1996-00 CL SOHC VTECH 2.2-2.3L
1992-95 CRX-Del Sol 1.6L VTEC
I was messing around on racenet and found this stuff what do you guys think?
