all motor build question
Old Jun 18, 2005 | 04:31 AM
  #21
Dang Yo's Avatar
Justa lil 6
Dang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the rough
Default Re: all motor build question
this is the new setup
CTR cams
JG springs/retainers/cam gears
skunk2 intake manifold
hondata intake manifold gasket
ARP head studs
usdm ITR .25 over pistons
stock rods and valves
ARP rod bolts
ITR oil pump
new main and crank bearings
RC 310 injectors
hondata S100
dc 4-1 header
omni power test pipe
2.5 ehaust
good numbers?
Old Jun 18, 2005 | 06:40 AM
  #22
SCOOBY STEVE's Avatar
sup
SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE
Originally Posted by split
I can say from experience with a setup very similar to that you will probably make ~160 to the wheels with a vafc. And the skunk 2 stage 2's are too big for that compression.
I made 164 on a GS-R on Hondata with I/H/E. I'm sure he'll be looking at mid to upper 170's
Old Jun 18, 2005 | 07:05 AM
  #23
soon2b's Avatar
soon2b has disabled reputation
you can get more compression out of a set of civic type r pistons
Old Jun 18, 2005 | 12:17 PM
  #24
dahatch's Avatar
dahatch is an unknown quantity at this point
use the stock head bolts they will be fine arp head bolts are waste of money if you you realy whant head bolts use aebs or the golden eagles
Old Jun 18, 2005 | 12:29 PM
  #25
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
mine worked fine honky.....
thats what i used in my ls vtec, no headwork or anything, some skunk 2 s2 cams, stock ls rods and made 178 to the wheels at 7800 rpm, car was fun, especially in vtec....but the car detonated like crazy even after it was tuned with hondata when i was under 4k rpm, shad and i drove around for an hour or so a little while after the dyno session to try and get a little street tuning at lower rpm and we still couldnt get it right, the pistons are so prone to heat so they detonate alot easier then forged shit....
Old Jun 18, 2005 | 12:32 PM
  #26
boostjunkie's Avatar
ITR prick #1...
boostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these partsboostjunkie is infamous around these parts
Originally Posted by fucT
I don't take my Type-R motor past 8200. I wouldn't take that motor past 8700. Especially only tuned on a VAFC. Rotational weight and momentum makes parts seem heavier. Add more speed into the mix and you'll over stress your engine. Type-R rods and some wiseco slugs at least and I would touch 9k, every once in a while.
i take mine up to 8500....
we'll see if yours outlasts mine. i would hope so...
Old Jun 18, 2005 | 12:34 PM
  #27
ITR prick #1...
Originally Posted by blackout
i was just under the impression that the b-series (especially the c5) was basically way overbuilt from the factory and you could rev the piss out of them with a clear conscience. like i said though, i've never had much to do with hondas, and i'm only interested now because my brother wants to build one.
thanks for the info though.
i wouldnt push mine past stock rev-limit....
Old Jun 18, 2005 | 02:51 PM
  #28
dahatch's Avatar
Smile Re: all motor build question
[QUOTE=MORE IMPATIENT]mine worked fine honky..... could of saved some money
AdubsGSR
Jan 24, 2009 12:11 PM
05chevyyy
Dec 22, 2008 03:37 PM
GreekCivicSI
Nov 16, 2007 05:13 AM
crxnfx
Jul 14, 2005 09:23 AM
