all motor build question
Well my friend is looking to build his GSR. here are his plans:::
skunk2 stage 2 cams
omni power springs and retainers
STR cam gears
ARP rod bolts
USDM ITR .25 over pistons and rings
bottom end gasket kit
tope end gasket kit
timing belt/water pump/ITR oil pump
walbro 255 intank pump
B & M FPR
new OEM main and rod bearings
question is will this setup be able to be tuned well enough without problems with a VAFC2
alreeady have a header and skunk2 intake manifold
and ITR ecu
skunk2 stage 2 cams
STR cam gears
ARP rod bolts
tope end gasket kit
B & M FPR
and ITR ecu
does the vafc have a feature to bypass the factory rev-limiter?
i'm sure those cams are going to want to go past 8000rpm... and you've got the bottom to handle it. oh yeah, get an ignition too.
Originally Posted by JayDM
You should have no problems at all using the VAFC to tune. Overall, its a pretty basic setup. Good choice getting rid of the stock GSR intake manifold!
Originally Posted by The Barst
nevermind, I didn't see the r ecu, you could still go higher, but 8700 is better than 8200
sounds like you got everything covered.
I wouldn't go higher on that bottom end combo. You are using stock heavy pieces. Unbalnced bottom end is not worth revving high. You can make some very streetable power with that, and it will make a great daily driver. Have fun.
