View Poll Results: Should I rebuild the LS:
sure, crack the head and attempt to rebuild
42.86%
sell it to the crazy fuck that wants to by it, and run with the money!
57.14%
Voters: 14. You may not vote on this poll
Interfence motor: build or not to build
Old 07-11-2005, 02:15 AM
I have a 20 valve...
crxnfx's Avatar
Default Interfence motor: build or not to build
Okay, last week my timing belt snapped on my 91 B18 LS engine. I looked it up, after a tip from the dealership that I called, and was told that it is an interference motor.
I looked it up online: click here, very useful
and found out that my car is an interference engine. Now, without even cracking the head open, a guy has offered me $1k for the car. Right now. And its tough as hell to even get parts here to italy so here is my dilemma
Keep the car : attempt to rebuild
Fuck it: sell it to the nutcase and get a beater for the next 9 months.
crxnfx is offline
Old 07-11-2005, 04:04 AM
Die reinste Bösen.
gear's Avatar
Default Re: Interfence motor: build or not to build
id sell it and save your money. then when you get a chance to get back into the game youll be ready. both finanicially and well, mentally.
gear is offline
Old 07-11-2005, 04:07 AM
corona connessuer
CHAHONDA's Avatar
put a timing belt on it and keep driving it. i know what is supposed to happen when it breaks but that is not always the case. i have replaced one on a 90 teg ls and the car started right up with out any problems. unless you were racing when it broke then everything should be just fine
CHAHONDA is offline
Old 07-11-2005, 04:15 AM
The Pro to call.
HatefulMechanic's Avatar
then again i replaced one on a 91 teg that broke while driving normally, and it bent three valves.
HatefulMechanic is offline
Old 07-11-2005, 04:55 AM
corona connessuer
CHAHONDA's Avatar
yup i suppose that you have a 50/50 chance. sounds shitty i know. pull the valve cover and check all of the rockers to see if any are very loose like ready to come out. if it were me id just buy a belt and try it to see if it worked. if not then all you have done is spent money on a timing belt and wasted about 2 hours in labor installing it. hell its just a thought. nothing like hearing from the person you sold the car to and having him tell you "man i just put a timing belt on it and i have been driving it for a few weeks"
good luck on your choice
CHAHONDA is offline
Old 07-11-2005, 07:13 AM
crxnfx's Avatar
yeah, now the guy is back peddeling.
"What? Nah man, I gotta take a look first. I don't wanna buy it if its broken..."
Fucker.
crxnfx is offline
Old 07-11-2005, 08:06 AM
Sumospeed #O.G.
SlowLS's Avatar
I broke a timing belt on my 94 ls, and nothing was wrong with it. new timing belt, and the car ran great.
SlowLS is offline
Old 07-11-2005, 08:07 AM
Ghost
MerF's Avatar
Fucker.
Kinda makes the decision easier for you I guess.
Just pull the head and check.
MerF is offline
Old 07-11-2005, 02:37 PM
The Pro to call.
you dont have to pull the head. yank the cams, and do an air test on each cylinder. or use a leakdown tester if you have it.
Old 07-11-2005, 09:57 PM
crxnfx's Avatar
I don't have either, and believe me its easier to take off the head. 10 nuts and its done.
crxnfx is offline
Quick Reply: Interfence motor: build or not to build
