axel swaps anyone?
Old 11-28-2009, 09:24 AM
jdmchef's Avatar
jdmchef jdmchef
Default Re: axel swaps anyone?
Well im not looking to trash it just mainly looking to go trail riding on the weekends
jdmchef is offline
Old 11-28-2009, 09:56 PM
Suzuki Fanboi
OverEasy's Avatar
OverEasy OverEasy OverEasy OverEasy OverEasy OverEasy OverEasy OverEasy OverEasy OverEasy OverEasy
www.Pirate4x4.com, They have Make specific threads. (Ford, Chevy, Toyota. . .)
Plenty info on this site.
OverEasy is offline
Old 11-30-2009, 01:57 AM
unclemeat's Avatar
unclemeat has disabled reputation
Two questions; What size tires are you going to run? What motor (horsepower)?
An 8.8 from an Explorer will let you run 38-inch tires and 400-horsepower.
It is a stronger axle than the D-44. There is not as much aftermarket support as the 9-inch. But you can get plenty of parts and support. These axles are extremely plentiful right now due to the cash for clunkers.
If you install extended radius arms, modify the shock mounts and disconnect the sway bar you can get a bunch of extra suspension travel on your existing front axle.
unclemeat is offline
Old 12-01-2009, 03:20 PM
Piss off
nissanfixer's Avatar
nissanfixer has disabled reputation
that is very true what he said about the travel on the ttb suspension. if it was me, id look for a high pinion 9 in and a 44. but the 8.8 can be a tough ass axle esp with moser axles installed
nissanfixer is offline
Old 12-01-2009, 04:24 PM
jdmchef's Avatar
jdmchef jdmchef
well my only concern is that when i put bigger tires and more lift with the stock front ttb suspenion is that the tires are goin to end up kicking out or having alot of negative camber. thats why i want to swap out with a straight axel up front.
jdmchef is offline
Old 12-01-2009, 04:25 PM
jdmchef's Avatar
jdmchef jdmchef
i have a good rear end in the truck now its just mainly the front axel
jdmchef is offline
AllMotorAllDay
11-03-2007 03:07 PM
cleanEK
06-07-2006 06:06 AM
cleanEK
06-02-2006 11:21 AM
Quick Reply: axel swaps anyone?
