Stretching tires?
Stretched sidewall are good for 2 things
-fitment *low offset+low ride height*
-keeps the sidewalls stiffer, more direct response from the tires. Good for drifting, makes no sense for much else
I've seen it on a few cars. I'm not asking whether you like it or not. Some people do some people don't. My question is.. is it anything more than buying a tire not quite wide enough and stretching over the rim to make it fit? Are the possibilites of tire failure greater because ofit? I'm kinda clueless on how it's done or the adverese effects it might have, so if anyone has any experiece with it... any info would help. Heres a pic... I'm actually thinkng about the color as well. Different
As far as stretched go, I have no clue.
I imagine stretching tires as doing several things. The bad would include making the tire more vonerable to popping a bead as well as less contact area (stay with me). Tires are designed to have a stiff corner (where the tread meets the sidewall) Think of an 'L' shape. Now when you bend the sidewall in, it also bends where the leg of the tread portion is pointing (essentially pointing the leg towards the center of the rim). This makes for uneven distribution along the tread (greater wear on the outside). I'm sure this could be compensated with a lot of air pressure. But this would harden the tire up like no other (why they do this for drifting). This is just the way I interpret it.
stretched tires are bad dont ever do it
its very dangerous and you can kil yourself
dont listen to the drifters they are idiots anyways
plus I see almost daily people popping beads of tires that are stretched
so dont do it cuz its like really really dangerous
and you lose bhp too from what I heard but I dunno first hand
just what I heard
......but dont do it
just what I heard
