need opinions on brakes
Old Sep 29, 2009 | 10:43 AM
  #41
BentValve's Avatar
Sorry. Not really.
BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve
Default Re: need opinions on brakes
Brand name rotors will do that too.
Old Sep 29, 2009 | 11:00 AM
  #42
The Wok's Avatar
DURRRRRRRRRRRRRRRRRR
Originally Posted by BentValve
I've used the greens and they were less dusty than OEM's but more dusty than Hawks. This was on my 11" brake kit using Brembo blanks and integra calipers.
wat?
Old Sep 29, 2009 | 11:08 AM
  #43
BentValve's Avatar
Sorry. Not really.
Originally Posted by The Wok
wat?
When I had my civic, I had an 11" Brake kit on it from Fastbrakes using an 11" brembo blank, integra caliper and fastbrakes caliper adapter. I used a set of EBC greens once and they gave off less dust than OEM but more dust than the Hawk pads I bought later down the road.
That help?
Old Sep 29, 2009 | 11:54 AM
  #44
jaqattack02's Avatar
jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02 jaqattack02
Originally Posted by D_Eclipse9916
+1 thats what they are intended to do, BUT you have to get quality slotted rotors.
There is a reason why Tirerack says to ABSOLUTELY to not use OEM replacements with slotted or drilled or dimpled rotors on track....
http://www.tirerack.com/brakes/tech/...currentpage=85
IMPORTANT REMINDER: Slotted, drilled or dimpled rotors offered as OEM replacements should not be considered appropriate for high-speed track use.
While grooved, drilled and slotted rotors offer an enhanced appearance and add some resistance to the boundary layer of gasses that can build up between the pad and rotor, they are not designed to withstand the extreme temperatures that are produced on the racetrack. If they are used on the track, it is very important that the rotors be carefully inspected and should not be driven on if even minor signs of deterioration are seen. Note, too, that if these products are used on the track they are not warrantable.
This is because the cheaper rotors usually have the slots/holes/whatever machined into them after the rotor has been cast. This creates micro fractures in the metal than can spread under hard, or sometimes even normal use. On high quality rotors the slots and stuff are cast into the rotor as it's made, so it's all one solid piece. When slotted rotors are OEM on a car (Porsche, Corvette, etc) the rotors are made this way to avoid any cracking issues.
upSLIDEdown
Suspension / Brakes
Mar 23, 2009 09:04 AM
