Lets talk breaks (Help)
stainless steel lines will take you out of STX (if they are non-flexable)
........must be stock except for the following.......
17.6 Brakes
B. Alternate DOT approved flexible brake lines.
17.6 Brakes
17.6 Brakes
17.6 Brakes
If the line isn't flexable then it could not be used to take up the for the movement on the wheel. It has to flex some. Therefore any line you use is flexiable if it works.
Trip is right again. August 2nd. BE THERE.
Originally posted by trip
SCREW PAX AND JUST SET UP YOUR CAR!!!!!
SCREW AUTOX AND GO TO VIR!!!!!!!!!!!!
I've got DOT approved, flexable SS lines on the Talon.. Along with a few other updates.. Need to update pads though. When I bought the Metalmasters, they were pretty good.. They aren't so hot now. Finally wore out the rears though, only took 5 years.
OH AND SCREW CLUTCHES... (right dave.
) HARDY HAR
) HARDY HAR
