Wheel/Tire Help w/ Towncar
Old Aug 28, 2008 | 08:47 AM
Gr0dy's Avatar
Gr0dy has disabled reputation
Default Wheel/Tire Help w/ Towncar
Basically i have a 92 lincoln towncar with the stock air suspension. I have my eye on some 20 inch rims that i would have to order off line , i was wondering if anybody knew if i could fit 20 inch rims on the car without adjusting the suspension. I know i could take the car to a rim shop and see if they would fit but id rather not waste the gas if someone on here could just answer it for me. The rims come with tires that have a profile of 45 i can get lower profile if its absolutely necessary but id rather not because it cost more money . Thanks in advance
Old Aug 28, 2008 | 08:53 AM
BentValve's Avatar
Sorry. Not really.
BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve
Default Re: Wheel/Tire Help w/ Towncar
It should fit, if not, make it fit.
Old Aug 28, 2008 | 04:28 PM
oxidejunky's Avatar
oxidejunky has disabled reputation
it will fit i had 20 x 8s on my town car and only had to beat in a little of the rear wheelwell. also would rub a bit on the swaybar up front if you turned the steering wheel all the way. You could either take the swaybar off or just grind it a cunt hair.
Mindphreak
Jan 9, 2009 05:10 AM
MVaughn
Jul 8, 2008 03:16 PM
slowr6
May 25, 2006 06:08 PM
