Turbo setup questions. Help :(
Old Nov 15, 2005 | 07:07 PM
  #21
Archer's Avatar
Super Secret Agent
Default Re: Turbo setup questions. Help :(
It was only running 7 psi today, so that is entirely possible. Nothing will be happening until this AFPR is replaced though.
Old Nov 15, 2005 | 10:26 PM
  #22
User 102020's Avatar
Here's some more detail:
The pieces I was adjusting on the AFPR were weak, and snapped apart with barely any effort. I'll probably send the AFPR to Flyin Miata and have them put new pieces on, make sure it's working correctly, etc.
Before that happened, as I was driving around, I had max fuel pressure adjusted to 98 psi, where it was supposed to be. However, shortly after it hit 98 psi, it would back itself down to about 90 psi, which coincided with the loss of power I've been feeling. Could this have been caused by a small fuel line leak somewhere?
We'll see as soon as I get this damn AFPR back on. It definitely feels like it'll be quick, though.
Old Nov 15, 2005 | 10:49 PM
  #23
What's happening to the boost level when the fuel pressure drops? If you're getting a drop in boost, the rising rate regulator may be dropping pressure. It does work off of the boost signal ya know..
Old Nov 16, 2005 | 06:41 AM
  #24
Boost stays at 7, doesn't drop, I'm pretty sure. No way to tell now as the AFPR is busted
BAN HAMMER
Feb 12, 2009 10:53 AM
xsilentwunx
Dec 22, 2007 02:35 PM
94_CRVtec
Aug 20, 2005 04:45 AM
2gdsm gst
Jul 7, 2005 05:52 PM
