transmission fluid
Old Sep 12, 2006 | 11:05 AM
EddieBell's Avatar
booooo
EddieBell has disabled reputation
Default Re: transmission fluid
Originally Posted by MaxPower
is it an auto or manual?
auto
Old Sep 12, 2006 | 04:54 PM
SlowLS's Avatar
Sumospeed #O.G.
If his tranny is already gone, then how would changing the fluid fuck up a fuck tranny? Think about it. Once the fluid gets old, it turns dark. Just like oil. It is an oil based fluid so it will eventually break down and need to be replaced.
Old Sep 12, 2006 | 07:32 PM
EddieBell's Avatar
booooo
the tranny is still in great condition.. nothing wrong when it changes gears just looking to do some preventative maint..
Old Sep 12, 2006 | 08:34 PM
MaxPower's Avatar
When clutch packs on the tranny burn out they can depend on the gritty ass fluid thats in there in order for them to not slip. Changing the fluid on a worn tranny is pointless if its going to need to be rebuilt anyway.
Bedward86: If its light brown, has a slightly burned odor, and you see little particles in the fluid its just starting to break down. This is the best time to get it flushed so the new fluid will lengthen the life of your tranny.
If its dark brown, smells burnt, and you can feel particles between your fingers and see crap in your pan then you might as well leave it alone.
Old Sep 12, 2006 | 09:25 PM
EddieBell's Avatar
booooo
its a medium brown color never got a chance to smell it. i dont think its worn at all just think the fluid needs to be changed but it not much of a car person as far as work. im going to call a few places and have them look at it...
Old Sep 13, 2006 | 03:11 AM
SPoolinspOON's Avatar
SPoolinspOON has disabled reputation
Did I miss something where he said he was talking about ATF? Or are you just basing that off the color or something. Honda Manual trans fluid is also red. Back on the subject. You can only fluch auto transmission. Manuals you can only drain and fill. Also if you have more than 100,000 miles, it is highly not recommended to flush the tranny. just drain and fill. If you want it do, pm me. I can do either at my work. If the fluid is old, change it. Do not let your tranny just die. Dont listen to these people saying keep the old fluid. New fluid will not cause any problems.
I would just drain and fill.
Old Sep 13, 2006 | 08:34 PM
EddieBell's Avatar
booooo
so you give a thumbs up but he said auto's you can only flush....
Old Sep 13, 2006 | 08:42 PM
The_rabbit1's Avatar
Fidel runs VBPD
The_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud of
You would be surprised at how many ppl put ATF in there manual.
you'd be surprised how many manuals use ATF.
also, where's the dipstick on a manual transmission? i want to see if my oil looks that color.
Old Sep 13, 2006 | 08:43 PM
Fidel runs VBPD
disconnect line to radiator, run till it drains, then refill.
Old Sep 13, 2006 | 08:47 PM
SlowLS's Avatar
Sumospeed #O.G.
You can drain and fill autos. you can not flush manuals.
