stipped the block head stud hole
Old Sep 9, 2006 | 09:01 AM
sive ick's Avatar
sive ick is an unknown quantity at this point
Default stipped the block head stud hole
i was tighting the head down after replacing my head gasket and i guess i over tightned it and the whole stripped.What is the best way to fix this problem?A thicker bolt,an longer bolt?
Old Sep 9, 2006 | 03:02 PM
Brycerb's Avatar
S-T-F-U
Brycerb Brycerb
Default Re: stipped the block head stud hole
Helicoil or something similar. DO NOT JUST RAM A BIGGER BOLT INTO THE HOLE. Their are ways to fix a stripped hole. It you do it right it will be just as strong as the original
Old Sep 10, 2006 | 07:34 AM
flat's Avatar
Blah!
flat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these partsflat is infamous around these parts
+1 Helicoil's..
Old Sep 10, 2006 | 08:13 AM
SwtNLow04's Avatar
SwtNLow04 has disabled reputation
you can get some arp head bolts. they thread deeper than the factory ones.
Old Sep 11, 2006 | 08:19 AM
spnamnt's Avatar
CIMSPORT
spnamnt has disabled reputation
theres a company that makes a kit specifically for doing this, but i forget who it is, it is the exact pitch of the honda head bolts and has the tool long enough to put the coils in
Old Sep 12, 2006 | 11:51 AM
sive ick's Avatar
well i just want to take the one out,not replace all,causing me to get a new 56 dollar headgasket,know what i mean?
if i get arp head studs can i take one head stud out at a time and save my head gasket,or even just helicoil that one.
Prices and specs please
Old Sep 12, 2006 | 03:42 PM
Brycerb's Avatar
S-T-F-U
Brycerb Brycerb
Go ahead and be cheap, and see if you don't pay for it in the long run.
Old Sep 13, 2006 | 05:51 PM
sive ick's Avatar
well im going to get another head anyways so back to the above
which is more preffered:
helocoil it or
arp head studs
and im not being cheap i just want to get it home then ill do all that jazz at my home
Old Sep 14, 2006 | 12:19 PM
sive ick's Avatar
ttt,also need z6 crank pully
Old Sep 15, 2006 | 07:08 PM
sive ick's Avatar
BLT4SIN
Dec 30, 2008 06:57 AM
SLO AZN
Oct 1, 2007 06:07 PM
buugiewuugie
Feb 13, 2007 07:40 AM
spooledex
Nov 8, 2006 12:31 PM
black6gen
May 10, 2006 06:18 PM
