SR20det owners I need help
Old May 8, 2004 | 01:06 AM
Hayashi's Avatar
Hayashi is an unknown quantity at this point
Default Re: SR20det owners I need help
Originally Posted by Fabrik8
Define "your car won't pass inspection period".. Are you talking about states with emissions testing or general state of VA inspection? I'm kinda scared, I'm about to do this swap..
Meaning that your car won't pass emissions, at all... any state... thats why its good to have a good close freinds in the automotive industry.. or ones that are good freinds with emissions people.
Old May 8, 2004 | 04:00 AM
Wickedy Wick's Avatar
Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick
Thanks for the info, did you just clamp that pipe or stick something in it that can really take some heat
Old May 8, 2004 | 04:53 AM
Glad we don't have emissions testing in VA..
Old May 8, 2004 | 06:39 AM
eng's Avatar
eng
Administrator
eng eng eng eng eng eng eng eng eng eng eng
Originally Posted by kota2240
Do they make a fsm in english for the SR or is going to www.srswap like the closest thing to it.
There are no online copies of a S13 FSM that I know of. All I've seen is S14 SR and S13 & S14 KA You should be able to find a real (the big ass book) one for $100+
Not true at all, several people have had their SRs pass emissions in states that require it. That does not however change the fact that according to the federal govt. it is illegal
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
Old May 8, 2004 | 12:54 PM
projsr20det's Avatar
projsr20det projsr20det projsr20det projsr20det projsr20det projsr20det
Originally Posted by zipties
1. Brake master cyl. Find the same size hose that goes down ur firewall. It goes into it.
2. Thats an AIV i think thats what its called. Its not needed. Its used for emissions in Japan. hence you are in America. Your car wont pass inspections, period. So remove the whole assemby. Cut off the pipe connected to the turbo elbow and shut it.
Nissan has been using the AIV valve in one form or another in US cars and trucks also. Yes, you can just cut it out. It helps by adding exhaust air at cold start ups which helps burn cleaner.
Old May 8, 2004 | 01:30 PM
So if i do decide to keep it, the bottom hose connects to the turbo elbow, what about the small nipple on top and the larger one in the middle, where would i connect them?
Old May 8, 2004 | 08:47 PM
The vacuum diaphragm on top is usually hooked up to a solenoid thats teed to the intake manifold and the larger hose connects somewhere in the intake track behind the maf.
Old May 8, 2004 | 11:31 PM
Hayashi's Avatar
yea you can pass emmission... if u pay extra.....
what do you mean you are glad va doesn't have emissions... yes we do.... don't we?
Old May 9, 2004 | 05:12 AM
eng's Avatar
eng
Administrator
Not for the state of VA, but maybe some counties require it (I don't know if they can even do that or if anyone even does). All VA has is a visual inspection, inspectors just make sure everything that's supposed to be there is there. Some states have sniff tests where they measure what the exhaust is putting out.
__________________
Old May 9, 2004 | 06:42 AM
Archer's Avatar
Super Secret Agent
We have emmissions tests in VA...they measure the % HC ppm and % CO that your car puts out along with other things. There is a visual test included as well.
