question about different VTEC motors?
when i was getting my h22 dynoed once the 2 people before me were getting k20's dynoed. one made 199 and the other made 203. they were both the jdm type r model with exhaust of course. i think the jdm type r has more aggressive camshafts and timing. i was so impressed that that was the stock motor.
the exhaust does help a little bit
it depends completley. your gonna spend more money on your h22 to get equivalent power of a b series. Yes a bseries comes with less power but its much easier to modify and an h22 in a eg is a tight fit most people actually crush the tps sensor if the dont beat the firewall out a good bit. B18c are most commonly plus you have rpms, better head more aftermarket attention. the thing your at a disadvantage is displacement but they have a replacement for displacement now its called forced induction.
[IMG]
[/IMG]this is with a skunk2 intake manifold which is much larger than factory.
here is an engine bay shot
[IMG]
[/IMG]there are no issues with space as long as you get good motor mounts. i used avid racing mounts. they set the motor back an inch farther than hasport for better balance and i still could fit the manifold.
you are not gonna spend more money to get the same power. parts for the h22 are more expensive but u get more power out of them. the h22 has more from the get go and is capable of more all motor power my jdm h22 put down 202whp with a skunk2 manifold custom headers, fpr, and crome. i could never do that with my b18c1 integra with out going into the motor. the only reason to go b series is if you plan on a turbo.
Aftermarket selection has not broadend for the h22. Its still overflooded with bseries parts. For around five hundred you can by a comple ebay turbo kit and 300 to get a chip and tune. the kits are of poor quality and the only parts worth keeping is the piping. but its a good start for those who want to boost. And these stock gsrs with a cheap turbo kit make more then 200 on a mustangdynameter. If hes going all motor why not go h22 thats a smarter idea. About beating the firewall i did a h22 swap in an eg with ???? mounts and the skunk 2 pro series intake and when the got on it he crushed his tps against the firewall. it was a real tight fit. He might of had softer inserts in his mounts but that was just from personal experience. so i just beat the fire wall where the tps and iac would hit for good measure. Maybe his was weird you obviously did it without beating the wall. BTW clean car the h22 looks sick in egs
h22 = all motor
b18 = boost
