pistons
Old Jun 14, 2004 | 09:32 PM
RPRacing's Avatar
Huntin Dropa ForLife
RPRacing has disabled reputation
Default Re: pistons
iknow you dont have 5000 to spend just on rods, but get some oliver or pauter rods with some CP or wiseco pistons. sleeve the block to 84 or 85mm. do 2000 worth of work to the ls head, or 1000 to the vtec head. save the rest of the $$$ on "in case shit"
Old Jun 15, 2004 | 02:35 AM
HORNY4ZORNY's Avatar
takin it all
HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY HORNY4ZORNY
Default Re: pistons
no vtec head, going with ls
Old Jun 15, 2004 | 03:25 AM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
Default Re: pistons
good luck making 200 all motor on the ls, i was on the same path, but then i saw the light, youll spend alot more than you want to if you want to make that kind of power on a non vtec motor,but it can be done, just dont think your gonna want to spend that kind of money, and pump gas would be out of the question........
Old Jun 15, 2004 | 03:28 AM
takin it all
Default Re: pistons
i want to get as close to 200 as possible
Old Jun 15, 2004 | 03:31 AM
DESTROYS DONUTS !!
Default Re: pistons
well than, you better resleeve your block and bore the fuck out of it and run like a 86mm piston,cause you aint doing it on stock bore........
Old Jun 15, 2004 | 03:39 AM
RPRacing's Avatar
Default Re: pistons
for a DD, 85 max. but yeah. sleeving is a must
Old Jun 15, 2004 | 09:27 AM
DoC-JoneS's Avatar
Doin' (today) stuff
DoC-JoneS DoC-JoneS DoC-JoneS DoC-JoneS
Default Re: pistons
stroke it. i mean if you want all motor and nasty stroking is a good option especially on a non vtec head. less revs means more reliable. def sleeve the block and 85mm would be all i'd run if you want to have it last a while. and forget 87 octane. it's crap.
Pew. Pew.
Engine / Exhaust / Drivetrain
20
Apr 7, 2009 05:34 PM
2 LATE U LOSE
29
Mar 12, 2009 02:01 AM
