oil in charge pipes?!
so i pulled my intercooler off my car last night and a buddy of mine pointed out there was a small bit of oil im my charge pipes? pretty sure thats not good. any ideas what could be causeing this.?
Turbo VTEC-E
Re: oil in charge pipes?!
Oil seals in the compresor side of the turbo are starting to go. Is there any oil in your exhaust?
Turbo VTEC-E
TurboPipingSystems
Before you do anything, I suggest that you inspect the oil drain tubing from your turbo to make sure that it is not kinked or angled poorly. Restricted drain flow can cause the same indications.
Turbo VTEC-E
Exactly. A kink in my return line is actualy what caused my first turbo 2 blow.
