No power
Old Feb 1, 2009 | 04:19 AM
99CivicB16's Avatar
Giggity Giggity Goo
99CivicB16 is an unknown quantity at this point
Default No power
I have a 99 Civic EX coupe with a b16a swap...the car has no power and backfires and sounds like a 4 wheeler....i replace wires plugs cap rotor...what do u think is the problem
Old Feb 1, 2009 | 10:28 AM
Default Re: No power
No CELs?
Old Feb 1, 2009 | 05:53 PM
92gsrteg's Avatar
92gsrteg has disabled reputation
i would check the timing to start with
Old Feb 2, 2009 | 04:24 AM
99CivicB16's Avatar
Giggity Giggity Goo
No CEL at all...it also starts and idles fine when cold....when it starts warmin up it cuts off unless i give it gas
Old Feb 2, 2009 | 04:41 AM
reddevil94's Avatar
Droppin E-Thugs!!!!!
reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94 reddevil94
Smile Re: No power
^^^What he said and verify the fuel injector plugs are on the correct cylinder. Read the manual and it should have the color code for the right cylinder.....
Old Feb 4, 2009 | 07:22 AM
SortaFlush's Avatar
Slammedxpert
Well, if it was timing it would do it all of the time wether is was cold or hot. Did you use a obd1 b16 or obd2 b16?
Old Feb 4, 2009 | 09:35 AM
No, that's not true. There are different enrichment logic depending on whether the ECU is detecting hot start or cold start. If the timing is mechanically off, it will do it all the time, but if the ECU is working off of faulty sensor data, it can change the ignition. This could very well be a MAP or TPS problem, or a bad knock sensor. Once the engine starts warming up there are some fuel trims based on the sensor data, so it could be one of those.
You're saying it's misbehaving at idle and off idle once it warms up, right?
Old Feb 4, 2009 | 10:13 AM
GreatShamanGT's Avatar
GreatShamanGT has disabled reputation
maybe it's too rich?
Old Feb 4, 2009 | 10:15 AM
integrab17's Avatar
ohh yea
integrab17 has disabled reputation
was the motor good ??? check compression
madsteez
Feb 3, 2009 10:42 AM
seanazzy
Jun 19, 2007 06:43 PM
