No power
I have a 99 Civic EX coupe with a b16a swap...the car has no power and backfires and sounds like a 4 wheeler....i replace wires plugs cap rotor...what do u think is the problem
Re: No power
No CELs?
Re: No power
i would check the timing to start with
Re: No power
No CEL at all...it also starts and idles fine when cold....when it starts warmin up it cuts off unless i give it gas
Re: No power
Originally Posted by 92gsrteg
(Post 4945795)
Re: No power
Well, if it was timing it would do it all of the time wether is was cold or hot. Did you use a obd1 b16 or obd2 b16?
Re: No power
Originally Posted by I spy Psi
(Post 4955578)
You're saying it's misbehaving at idle and off idle once it warms up, right? |
Re: No power
maybe it's too rich?
Re: No power
was the motor good ??? check compression
