New intake manifold, High Idle
Old 12-27-2010, 11:50 PM
  #21
GSRswapEk's Avatar
GSRswapEk has disabled reputation
Default Re: New intake manifold, High Idle
Originally Posted by Topik
do none of you people actually RESEARCH these parts before throwing them on your car? most of the latest threads i've read in tech-talk could be solved by a .2 second google search or a thimble full of automotive knowledg.
dont have to be a smart ass, just hit the back button
GSRswapEk is offline
Old 12-28-2010, 12:00 AM
  #22
i need a civic!'s Avatar
i need a civic! has disabled reputation
ehh hes right. before asking atleast try to search. i guess people like rely on this site more than theirselves ha. check for leak. dif ecu=golden.
i need a civic! is offline
Old 12-30-2010, 09:07 PM
  #23
Band
paperassgasket's Avatar
Originally Posted by Fabrik8
By the way, if you're using a GSR ECU, you'll need to use a different ECU or get the ECU chipped (if it's an OBD1 ECU) so that the ECU won't try to control the secondary butterflies that aren't there anymore.
urite.
the result is it may be running a bit lean. I'd also check all coolent / intercooler fittings or connections and probably the easiest thing to check is spray some wd40 around all the intakes joints and connections. if the idle changes at all, there's your problem. (after you map the ecu of course)
paperassgasket is offline
GaRn
07-15-2006 07:59 AM
Quick Reply: New intake manifold, High Idle
