need opinions on head work
Old 05-10-2006, 06:59 AM
kyl3's Avatar
kyl3 has disabled reputation
Default need opinions on head work
i have a 2000 si and the head has all skunk2 stage 2 parts. i want to boost the motor but i dont know if i should keep the head the way it is or should i change it. please give me some opinions on what to do.
kyl3 is offline
Old 05-10-2006, 07:18 AM
Captain Deeeez Nutzz
b16 snatch's Avatar
b16 snatch has disabled reputation
Default Re: need opinions on head work
i've got pro-series in mine and was wondering the same thing
b16 snatch is offline
Old 05-10-2006, 08:02 AM
As a general rule of thumb, cams that work well for N/A use aren't the greatest for turbo use.
Old 05-10-2006, 09:13 AM
Kimchee Wiggler
Boostfed's Avatar
Boostfed Boostfed Boostfed Boostfed Boostfed Boostfed
Wrong Many people now are starting to use Skunk2 Stage 2 cams for turbo and making alot of power. Also combinatiosn of Skunk Stage 1 exhaust with Jun Type 2 intake cam. Many many many high lift long duration cams are being used these days on turbo set ups.
Boostfed is offline
Old 05-10-2006, 09:34 AM
That sounds good, the exhuast side is the pickier of the two, which is probably why that Jun stage1 is popular instead of a more radical grind. The intake can go a little more radical, yeah.
I should have qualified my statement as exhaust side for DOHC stuff.
I know people use stage X cams and make good power, but the fact remains that (for exhaust especially) the higher tuned they are for N/A use, the less optimum they'll be for a turbo setup. It's mostly overlap, duration, etc., that's the problem. More lift is a good thing, it's the change in timing and duration that can get you into trouble. This really depends on how well optimized the whole system is though, it may work fine for you.
Old 05-10-2006, 11:12 AM
kyl3's Avatar
thanks alot for the advice guys
MOTOR
B16A2
Skunk 2 Stage 2 Cams
Skunk 2 Cam Gears
Skunk 2 Intake Manifold
Skunk 2 Valve Springs
Skunk 2 Retainers
AEM Cold Air Intake
DC Sports Cat Back Exhaust
Stage 3 Clutch
Integra Type R Header (Wrapped)
AEM Fuel Rail
Hondata Intake Manifold Gasket
BBK 70mm Throttle Body
Gutted Cat.
Hasport Driver Side Motor Mount
Prolight Inserts On Passenger Side
MSD Spark Plug Wires
Custom Yellow Valve Cover
these are the mods what should i keep or change for turbo
kyl3 is offline
Old 05-10-2006, 11:33 AM
DumpedDA's Avatar
DumpedDA has disabled reputation
sleeves. low compression pistons.
DumpedDA is offline
Old 05-10-2006, 02:37 PM
Kimchee Wiggler
Boostfed's Avatar
MOTOR
B16A2
Skunk 2 Cam Gears
Skunk 2 Retainers
AEM Cold Air Intake
Stage 3 Clutch
AEM Fuel Rail
Gutted Cat.
Yeah definately keep the Custom Yellow Valve Cover
Boostfed is offline
Old 05-10-2006, 04:44 PM
b16 snatch's Avatar
damnit i was gonna say that
Old 05-10-2006, 05:06 PM
Gracie Jiu-Jitsu
05WRX's Avatar
05WRX has disabled reputation
best advice i can give you is to call this number and ask for brian, he'll be able to help you with any Honda advice you need. (757) 853-7771 Tell him andrew told you to call.
05WRX is offline
elambz
11-21-2008 07:57 AM
420a rider
11-03-2004 11:36 AM
-GoKart-
08-23-2004 08:23 PM
-GoKart-
06-27-2004 06:21 PM
Quick Reply: need opinions on head work
