Need a Honda Guru...
Check voltage drop from a clean spot on the block to the negative battery post (and I mean the post, not the clamp terminal). This will tell if you have a corroded ground. If that is good, check that you are getting power to the starter (also check power to the start solenoid, which may be built in to the starter so this may not apply).. If that is good, disconnect the starter power (for safety) and see that the start solenoid coil is getting switched on (actually I think most cars get switched to ground, I don't remember). If everything looks good up to this point, look for cracked battery clamp terminals and that sort of thing. It's possible for a voltage check to come out perfect when statically tested but the whole system could still fall on it's face if a cracked/loose battery terminal doesn't allow enough current to flow for starting. First things first though, check to see where you have voltage and where you don't.
Well today I took the battery to Auto Zone and got it recharged. Got home and before I installed the battery, I cleaned the tranny, battery and valve cover grounds. Put the battery in and everything works fine. (knock on wood)
Hopefully it'll stay like that..... We'll see.
Thanks guys.
Thanks guys.
If you had to charge the battery you might want to check your alternator. Around 14 and a half volts at idle is normal. You should load test it but i dont think you have the tools for that.
Sounds like a typical ground problem. I had a similar problem with my WRX a few years ago.
Alternator voltage shouldn't be 14.5V at idle, unless your idle is really fast.
Jarrod
Aug 13, 2007 08:25 AM
