Need help. Pistons skirts coated, fitting too tight into cylinders...
Old 03-14-2010, 06:30 AM
Cypren's Avatar
Cypren has disabled reputation
Default Need help. Pistons skirts coated, fitting too tight into cylinders...
delete
Cypren is offline
Old 03-14-2010, 06:45 AM
tits anyone?
I Love (.)(.)'s Avatar
I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.) I Love (.)(.)
Default Re: Need help. Pistons skirts coated, fitting too tight into cylinders...
correct me if im wrong, but if you buy a "coated piston" it shouldnt be wearing off eventually. wouldnt that defeat the purpose of the coating? ebay=
edit*- are the rings correct?
I Love (.)(.) is offline
Old 03-14-2010, 07:19 AM
Team Ultraspeed
Yell88CRXsi's Avatar
You do know that when boring a cylinder...you are suppose to bore it to match the piston that you are using that cylinder. You can not just "bore" a block out to 81.5mm and expect the every 81.5mm piston out there to fit. It doesn't work that way.
You need to take these "new" pistons and your block to a machine shop and have the cylinders bored to match each piston.
Yell88CRXsi is offline
Old 03-14-2010, 09:44 AM
Yep, take them to the machine shop and get them both measured. This should be easy to sort out. You shouldn't have got the block bored until you actually had the pistons in your hands anyway.
RandomTask
01-05-2008 09:28 AM
dogg2k78
08-22-2006 09:01 AM
fourwhls
08-16-2006 04:15 AM
Quick Reply: Need help. Pistons skirts coated, fitting too tight into cylinders...
