need help no fuel pressure at all
Old 02-16-2013, 06:40 PM
integrab20's Avatar
integrab20 has disabled reputation
Default need help no fuel pressure at all
got new b20 vtec swap on my integra the car crank but no fuel pressure at all the relay wont click but when i check the relay i dont see any crack or anything i just wanna know if anybody experience or happen like this just need help any idea
integrab20 is offline
Old 02-17-2013, 05:54 AM
sleeperteg's Avatar
sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg sleeperteg
Default Re: need help no fuel pressure at all
If you cannot hear the relay click it doesn't need to have a crack on it to be bad. Replace it with a known good part and also check the fuse for the fuel pump under the dash. Check all engine grounds
sleeperteg is offline
Old 02-17-2013, 06:23 AM
fuck this shit
grgazn's Avatar
grgazn grgazn grgazn grgazn grgazn grgazn grgazn grgazn grgazn grgazn grgazn
Depending on the year teg there are a few places to check. Check the under-hood fuse box. The small fuses at the top. One should say backup and another ecu. If those are good, go to your in car box. Check your srs fuse. Believe it or not, this can disable the ecu and subsequently the main relay.
Next check ecu. Make sure it is plugged up all the way and not damaged.
Finally, check grounds. Engine, transmission, thermostat. That thermostat one can mess a lot of stuff up
Let me know how those go and ill try to help you more. Good luck!
grgazn is offline
sircrx
05-08-2011 12:17 PM
341am
04-27-2010 06:09 PM
buugiewuugie
01-10-2007 05:23 PM
ScrewD03
11-13-2004 12:31 PM
Quick Reply: need help no fuel pressure at all
