need help greddy emanage?
Old Apr 9, 2006 | 06:53 PM
99 ek9's Avatar
99 ek9 has disabled reputation
Default need help greddy emanage?
i have a 99 civic hatch with jdm gsr swap turboed @ 5 psi i bought a greddy emanage from a friend so i can tune my car and try to run 10-12 lbs of boost
i installed it and now i cant even get it to start all the settings are on zero and timing and all should be normal does anyone have a base map or any kind of map for there emanage? what should i do? if i cant figure it out imma sell it so if u can help please do
Old Apr 9, 2006 | 07:48 PM
Zen's Avatar
Zen
Zen Zen Zen Zen Zen Zen Zen Zen Zen Zen Zen
Default Re: need help greddy emanage?
What options did you get with the Emanage. You need extra harnesses to adjust certain things: (ie: Ignition harness for timing), pressure sensor, injector, etc.
Old Apr 9, 2006 | 08:17 PM
Fobby's Avatar
Classified Moderator
Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby
yep
Old Apr 10, 2006 | 04:15 AM
ZeroMR's Avatar
I'm still slow.....
ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR
Pm superls92, he tuned his with emanage.
Old Apr 10, 2006 | 06:41 AM
99 ek9's Avatar
it has pressure, injector and rpm signal and ignition signal bascally every option that u can buy for it except knock sensor i believe
Old Apr 10, 2006 | 07:31 AM
brnzbuddha's Avatar
EMF Member #12
brnzbuddha has a reputation beyond reputebrnzbuddha has a reputation beyond reputebrnzbuddha has a reputation beyond reputebrnzbuddha has a reputation beyond reputebrnzbuddha has a reputation beyond reputebrnzbuddha has a reputation beyond reputebrnzbuddha has a reputation beyond reputebrnzbuddha has a reputation beyond reputebrnzbuddha has a reputation beyond reputebrnzbuddha has a reputation beyond repute
sohc_mshue can help ya out i believe. pm him.
Old Apr 12, 2006 | 06:40 PM
superls92's Avatar
superls92 is an unknown quantity at this point
It sounds like you don't have your jumpers set correctly. If you have the harness for the injectors then you need to set the jumpers for that, and there is another jumper that you change if you are the using ignition harness.
iFoam
Dec 20, 2007 07:16 AM
Al_P
Sep 3, 2006 12:21 PM
El Negro
Feb 18, 2004 02:12 PM
