crx mini me help
Old Apr 8, 2006 | 12:15 PM
crxgsr2004's Avatar
crxgsr2004 has disabled reputation
Default crx engine code ??
have a 91 crx with a d15b7 bottom end and a z6 head the prev owner has a b16 ecu and its throwing a crank angle code what is it and haow do i fix it
thanks jake
Old Apr 8, 2006 | 12:28 PM
idriveahonda's Avatar
Shooting 63's
Default Re: crx mini me help
Well you want to get a z6 dizzy first off. Get the dizzy that goes with the head. Then you will want to go with the p28 ecu, which is the ecu for the z6, or use the stock p06 dx ecu and have someone convert it to run vtec and diff fuel maps when vtec kicks in. Anyone have anything to correct if I'm wrong?
Old Apr 8, 2006 | 12:31 PM
crxgsr2004's Avatar
how do i turn a z6 obd1 dizzy to fit a obd0 socket and how do i get p28 ecu to work on obd0????????????//
Old Apr 8, 2006 | 12:47 PM
DOHC crx VTEC's Avatar
DOHC crx VTEC is an unknown quantity at this point
You have to re-wire the distributor plugs with OBD-1 Plugs "the grey ones, I had schematics somewhere for it, you will probably need obd-1 intejectors, I suggest just getting a full Z6 intake manifold, get a P28 and an OBd-1 Conversion harness for the ecu. Look on ebay for some of the item's and then go to a junkyard and cut the dizzy plugs off a obd1 car.
Old Apr 8, 2006 | 04:09 PM
crxgsr2004's Avatar
thank you.
Old Apr 8, 2006 | 04:37 PM
thank you.
You're welcome. Pm me if you need help?
Old Apr 9, 2006 | 08:32 AM
Go here. I don't know about the dizzy, but this will take care of the ECU for you.
http://www.dragva.com/forums/showthread.php?t=134048
Old Apr 10, 2006 | 02:05 PM
crxgsr2004's Avatar
thanks
Old Apr 10, 2006 | 05:39 PM
Ross's Avatar
Ross is an unknown quantity at this point
You can not use a OBD0 ecu and a OBD1 distributer. The pickup wheels have difrent numbers of teeth between the two generation. I would recomnd trying to transplant the parts between the two if possable or do an OBD1 convrsion.
Old Apr 10, 2006 | 06:17 PM
CHAHONDA's Avatar
corona connessuer
lord...the easiest way to get around all of this crap would be to use a y8 head and then the stock distributor would work fine. id get a y8 manifold as well. the y8 heads also increase compression slightly.
