Need Help Civic Si
it means the distributor needs to be replaced. It's rust dust.
Did you empty the catch can? Is it between the valve cover and the intake? If your sucking shit into the intake from the can you might as well be sucking water into the motor. It could also throw a code like you have. EMPTY IT, change the plugs, then drive it.
"Why are you running Uberdata and now e-manage? Crome is the way to go...
Get rid of the e-manage piggyback bullshit, aside from AEM... Crome is the only other management I would rec. for a honda."
you forgot Hondata, the best.....
I would think injectors last. What size do you have? If they are bad I have some rc330's if you need some with the clips.
i think its your dizzy not getting enoug spark,try to advance it,my car did the same thing,sputter and hesitate when trying to accelerate,and get some fuel system cleaner and replace your fuel filter
Fuel filter has been replaced. Still no go How much would you part with your injectors because the ones i have right now are the rc310's. But i think i am going to order 440's today. You think I can try those injectors and see if that helps me fix my problem. I will try and empty the catch can today and see what happens.
Do not advance the timing on a boosted engine wihtout tuning it. Good way to blow your shit up right there.
MAVA !!!!
"YOUR PROBLEM IS THAT YOU HAVE BEEN RUNNING ON BASEMAP FOR ALMOST A YEAR NOW &
ALSO STILL ON YOUR FIRST SET OF SPARK PLUGS!!!! "
Go see Matt for a tune on the dyno!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
