Need Help Civic Si
Old Jun 13, 2007 | 07:08 AM
dogg2k78's Avatar
PS3OT
dogg2k78 has disabled reputation
Default Need Help Civic Si
I have a 99 Civic Si and when I accelerate the car the car sputters and doesn't want to go anywhere. When i just feather accelerator the car drives fine. Under 2000 rpms is when it is the worst. Also what has happened lately was when i fill up the car the car struggles to start and I have to hit the gas to start the car.
Old Jun 13, 2007 | 08:43 AM
-JB-'s Avatar
Fitty Tuckin
Default Re: Need Help Civic Si
Sounds like a problem in the fuel system. Bad fuel pump, injectors, fuel filter. How are the spark plugs? Bad MAP sensor?
Old Jun 13, 2007 | 09:01 AM
DecentCivicZ6's Avatar
DecentCivicZ6 is an unknown quantity at this point
you throwing any CEL?
Old Jun 13, 2007 | 10:00 AM
Jarrod's Avatar
braap braap
Its called a B16.
Old Jun 13, 2007 | 11:48 AM
dogg2k78's Avatar
PS3OT
Originally Posted by Jarrod
Its called a B16.
LOL
I'm not throwing a cell because I am running a uberdata with an obd1 ecu. Is it possible that if it misfires it can cause the car to hesistate like that.
Old Jun 13, 2007 | 11:49 AM
dogg2k78's Avatar
PS3OT
I'm going to check the spark plugs when it stops raining.
Old Jun 13, 2007 | 06:06 PM
Jarrod's Avatar
braap braap
Originally Posted by dogg2k78
LOL
Have you checked the cap and rotor?
Also, when was the last time it had the fuel filter replaced? I think it should be replaced every 15,000 miles.
Old Jun 13, 2007 | 06:43 PM
CHAHONDA's Avatar
corona connessuer
well having to hit the gas to get it to start is a symptom of flooding.
seems to me like you have a fueling issue. are you running real rich? black smoke? are your injectors leaking? WHAT SPARK PLUGS ARE YOU USING? what else has been done to the car? turbo? fuel pump? have you tried switching back to the stock ecu? i need some more info if i am going to be able to help you.
Old Jun 13, 2007 | 07:49 PM
JSL1CE's Avatar
standalonecomplex
JSL1CE is infamous around these partsJSL1CE is infamous around these partsJSL1CE is infamous around these partsJSL1CE is infamous around these partsJSL1CE is infamous around these partsJSL1CE is infamous around these partsJSL1CE is infamous around these partsJSL1CE is infamous around these partsJSL1CE is infamous around these partsJSL1CE is infamous around these partsJSL1CE is infamous around these parts
check your ignition first then your fuel system. good luck
Old Jun 13, 2007 | 08:01 PM
Akanuggetz's Avatar
Fresh Prince
Akanuggetz Akanuggetz Akanuggetz Akanuggetz Akanuggetz Akanuggetz Akanuggetz Akanuggetz Akanuggetz Akanuggetz Akanuggetz
i kinda had the same problem in my 89 civic, check your ignition coil and distrbutor rotor. after that, check your fuel system
