need help!!!!!!1
Old Jan 3, 2003 | 11:05 PM
one pnt 8 hatch's Avatar
The Dune Coon
one pnt 8 hatch is an unknown quantity at this point
Default need help!!!!!!1
aight i jus got back from the races. and i was bored so i decided to do a lil tune up work to my car. i was jus gonna djust valves and mess with the distrib timing. as i am removing the spark plug wires i see they are covered in oil then as i look at the spark plugs them selves they are surrounding in a huge ass puddle of oil all of them. i know its not head gasket cuase the car is still runnin strong. do i need to change the valve cover gaskets??????????? or what?? and another thing if the AIC valve went bed and i was constantly idolin at high revs like 2700 to 3500 would that effect my redline??????? and what is a 90-91 LS redline supposed to be??????
Old Jan 3, 2003 | 11:07 PM
ONEFLYAZN's Avatar
ONEFLYAZN ONEFLYAZN ONEFLYAZN ONEFLYAZN ONEFLYAZN ONEFLYAZN ONEFLYAZN ONEFLYAZN ONEFLYAZN ONEFLYAZN ONEFLYAZN
i would guess its the valve cover gasket... aint but like 20 bucks... and is easy to put on... if you get the valve cover gasket kit.... you can replace the o rings too..
Old Jan 3, 2003 | 11:09 PM
The Dune Coon
aight well that helps me out a lil. anyone bout that iac valve or the redline question?????????????????
Old Jan 4, 2003 | 06:06 AM
CHAHONDA's Avatar
corona connessuer
i think redline is like 6800
i can fix it!!!!
Old Jan 4, 2003 | 07:34 AM
The Dune Coon
will a bad iac valve drop my redline???????? and i can fix it jus need parts. but if ur willin to donate ur time and some parts go right ahead i aint stoppin u
Old Jan 4, 2003 | 07:39 AM
Mr. Rooney's Avatar
Registered Offender
Mr. Rooney is an unknown quantity at this point
no to the redline question, it only affects idle. the gaskets are the four round ones that are under the valve cover.
Old Jan 4, 2003 | 07:46 AM
The Dune Coon
could it be doing that cuase im missin 2 grommets for the valve cover and its not gettin a complete seal?????
Old Jan 4, 2003 | 07:56 AM
blackout's Avatar
master debater
blackout blackout blackout blackout blackout blackout blackout blackout blackout blackout blackout
which grommets are you referring to?
just put a valve cover on it and change your plugs. couldn't hurt anything.
Old Jan 4, 2003 | 07:58 AM
The Dune Coon
i already got new spark plugs in it but the lil rubber/metal grommets that hold the actual valve cover down.
Old Jan 4, 2003 | 08:14 AM
The Dune Coon
can u adjust the iac valve?????
