need help!!!!!!1
Old Jan 4, 2003 | 08:41 AM
richard dalton's Avatar
zoomzoomzoom
richard dalton is an unknown quantity at this point
i could get you a couple of buck's off that gasket if you want
Old Jan 4, 2003 | 08:42 AM
one pnt 8 hatch's Avatar
The Dune Coon
one pnt 8 hatch is an unknown quantity at this point
i can get a few dollars off too
Old Jan 4, 2003 | 09:12 AM
zoomzoomzoom
i got mine for 11 bucks through my work can get almost everything cheap(except performance shit)...............
Old Jan 4, 2003 | 09:40 AM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
your tube seals are leaking big time, mine did the same thing, they just get old after a while, replace the tube seals, the 4 ruber circle gaskets, they slide right into the underside of the valve cover, and then get a valve cover set, replace the gasket, put some hondabond on the corners of the gasket and where the gasket makes a half circle to cover the cam side, then check that shit later, that should fix your problem.......
Old Jan 4, 2003 | 02:17 PM
blackout's Avatar
master debater
blackout blackout blackout blackout blackout blackout blackout blackout blackout blackout blackout
and no you can't adjust the iac. what an iac is is a valve that is actuated by a motor that opens allowing air to bypass the throttle plate at idle to keep the car running with no throttle. what happens is the motor gets weak over time, or the valve gets clogged with carbon and sticks, causing an erratic idle concern. one easy way to tell is when your idle shoots up tap the motor with a screwdriver or something and see if the idle returns to normal (doesn't work ALL the time, but it is a sure way to tell that's what the problem is if it does work). the only way to permanently correct this is to replace the iac.
Old Jan 4, 2003 | 03:44 PM
B18aCrIx's Avatar
Team Ultraspeed
B18aCrIx is on a distinguished road
if you are having oil on your sparkplugs when you take them out you need some new tube seals, and make sure before you put the new plugs clean the sparkplugs and wires
Old Jan 4, 2003 | 03:46 PM
The Dune Coon
i got everything on right and its not leakin no more put its misfiring a lot i have no clue why. and ideas?
Old Jan 4, 2003 | 05:05 PM
zoomzoomzoom
wrong spark plag gap?
Old Jan 4, 2003 | 05:07 PM
The Dune Coon
they are gaped and my valve cover is fine now
Old Jan 4, 2003 | 05:26 PM
zoomzoomzoom
does the engine shudder real bad when you rev it up. if it does checks you spark plug wires
