MULTI POINT CONVERSION PROBLEM!
Very rarely will ALL 4 injectors fail. Check your wiring against that link I posted.
Does your ECU light flash when you first insert and turn the key? BTW, what ECU are you using?
This stuff is simple - this is not like building a particle accelerator.
One flash for obd0 isn't that the code for the ecu being bad? Something on the ecu might have gotten burned up causing your fuel injector issue
I'm bout too go crazyy
I have got an new ecu pr4 and a pm6 I found out they both work fine
Okay I checked the main relay fuses there good
This what I did so far the multi point conversion
I ran 4 wires from a1 a3 a5 a7 through the firewall to the injectors
Then by the plug on the driver side I unplugged the thick yellow/black wire
And connected that to the resistor box then the 4 wires to the box from the injectors
Fast forward I'm getting spark ecu throwing no codes. Fuel getting to the rail with pressure
But STOPS AT THE INJECTORS WTF... I'M STUCK PLZ HELP
VTEC juice clogged your injectors! lol
Where are you located?
If this goes on any longer, I'm willing to look at it this weekend just to close your topic
or give you $100 for the whole pile
