MULTI POINT CONVERSION PROBLEM!
Old May 2, 2010 | 05:51 AM
  #21
dseayman's Avatar
dseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these partsdseayman is infamous around these parts
Default Re: MULTI POINT CONVERSION PROBLEM!!!!!!!!!
Bump Help
Old May 2, 2010 | 07:20 AM
  #22
team703's Avatar
Who did the dpfi to mpfi wiring? Maybe the injectors are wired incorrectly.
Old May 2, 2010 | 07:24 AM
  #23
Jenkinsal2's Avatar
Jenkinsal2 Jenkinsal2 Jenkinsal2 Jenkinsal2 Jenkinsal2 Jenkinsal2 Jenkinsal2 Jenkinsal2 Jenkinsal2 Jenkinsal2 Jenkinsal2
check the injector wiring. If there is no fuel going through them then they are not pulsing. To clarify. If you are using obd1 injectors you will not have a resistor box. If you are using obd0 injectors you will need the resistor box. I have a feeling that you wired the injectors incorrectly.
Old May 2, 2010 | 07:32 AM
  #24
team703's Avatar
^^^^^^^^^^^^^^Sounds like it, Hope Op didn't just take an SI harness and plug it up and think it will work........
Old May 2, 2010 | 06:07 PM
  #25
dseayman's Avatar
i have an pm6 ecu with an si dizzy and obd1 injectors
Old May 2, 2010 | 06:10 PM
  #26
Jenkinsal2's Avatar
how have you wired the injectors??? THIS IS YOUR PROBLEM MOST LIKELY!!!
Old May 2, 2010 | 06:12 PM
  #27
dseayman's Avatar
4 wires running too the ecu a1 a3 a5 a7 then the positive all connected
Attached Thumbnails MULTI POINT CONVERSION PROBLEM!-mms_picture.jpg   MULTI POINT CONVERSION PROBLEM!-1.jpg
Old May 2, 2010 | 07:02 PM
  #28
team703's Avatar
Have you checked for power with a voltage meter thru the injector clips?
Old May 2, 2010 | 07:21 PM
  #29
dseayman's Avatar
I don't have one but ii can get one
Old May 3, 2010 | 01:45 PM
  #30
dseayman's Avatar
Okay everybody I jus put in my obd0 injectors with a res. Box wired this shit up the right way but still no power pulse. The ecu not throwing any codes alt all..... Stuck ill take pic n send them too ya phone or email
