LS Problems
Old 06-23-2009, 10:20 AM
Grippin the Grain
importfanatic's Avatar
importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic importfanatic
Default LS Problems
93 Acura Integra 1.8L Non-VTEC (stock)
Alright, my problem is when it gets really hot outside, like it has been these past couple of days, my car won't start. It will crank but it won't start. My battery was reading good, my starter cranks hard, and I can smell fuel, but there just isn't a spark. I took a plug wire off the dizzy and tried to start it and the spark was very weak. I recently replaced the dizzy with a brand new one, but the symptoms I have now are the same symptoms that lead me to buying a new dizzy. I can go out in the morning and start my car with no problem at all, but when it gets warm (around 2-4), it won't start. What could be casuing this? Is it possible that my high cabin temperatures are screwing with my ecu?
importfanatic is offline
Old 06-23-2009, 12:22 PM
1rude2l's Avatar
Default Re: LS Problems
Are u absolutely sure its getting fuel? Usually when the main relays act up, is when it gets warm outside. That could be your problem. Try finding another and checking it out. Maybe a friend has one available.
1rude2l is offline
Old 06-23-2009, 12:25 PM
Grippin the Grain
Now that you mentioned that, I do remember hearing a weird buzzing noise from under the hood. I couldn't really tell where it was coming from, but it only does it when the key is in the on position.
Old 06-23-2009, 07:58 PM
CustomGSR
kaltares's Avatar
kaltares is an unknown quantity at this point
that noise is probably your abs its low on fluid.
kaltares is offline
Old 06-23-2009, 08:16 PM
Sup, ladies?
Lestar's Avatar
Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar
Main Fuel Relay. Try hitting it while trying to start your car up.
Lestar is offline
Old 06-24-2009, 07:01 PM
Grippin the Grain
Not equipped with abs.
Where is that exactly? The noise I'm hearing is coming from the area in between the radiator and my passenger side headlight.
tp teddy
02-09-2006 07:21 PM
To0C0oL
09-16-2005 06:45 AM
hondacrix
04-22-2004 05:25 AM
Aquavit
06-30-2003 04:11 PM
Volkswagen
04-09-2003 06:22 PM
Quick Reply: LS Problems
