crx si timing specs help
look what you did!
I need help finding a good page with the specs for the timing on a d16a6, I had no problem finding for a dx civic about two months agos now i'm sir struggles with this one, wtf! I'm just trying to figure out where the timing marks on the crank pulley should be at tdc. HELP!!
Va Beach Coast Rider
Re: crx si timing specs help
Should be two different marks; a single line and then three lines with the center one being red. They won't line straight up; they will be at an angle towards the rear of the car. You need the lower plastic cover plate on to see the mark on it for TDC.
look what you did!
I had to replace the head on the motor, so it is the red one , I couldn't remember which one it was, thank you! What about the timing light 1ts 18deg. b4 tdc right?
oxsleeperxo
05-15-2008 03:38 PM
