installing jdm climate control
Old Oct 1, 2003 | 08:32 AM
  #21
Skywalker's Avatar
Atheist.
Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker
So there's no extra features or different color backlighting or anything? It's just the same exact panel aside from the fact that it was from a Japanese vehicle?
Old Oct 1, 2003 | 08:51 AM
  #22
sung's Avatar
Site Founder
sung sung sung sung sung sung sung sung sung sung sung
it's aesthetically different and it lights up amber. it also has celcius readings.
Old Oct 1, 2003 | 08:52 AM
  #23
sung's Avatar
Site Founder
copied and pasted from honda-tech.
Switching the climate face is fairly simple. You need to first remove your radio and lower panels to gain access to the climate control. There are 4 screws that need to be removed. One in the rear, which is almost identical to the radio screw, and 3 on the "face" of the climate control. There are two on the sides, which are larger screws. You will probably have to lie on your back to get to them. The last screw is very small, and will require one of those tiny electronics screwdrivers. It is the actual screw that holds the face of the climate control on the unit. After you have removed all 4, the entire unit should be able to slide forward about 2 inches. You will then have to find a way to remove the slider buttons...I used a pair of pliers and cushioned the pliers with a rubber band then grabbed them like I was pulling a tooth. They pop right off, so pull hard. Then, there are I belive 3 tabs holding the face on. Use a small flathead and gently pry them up and slide the face off. Once that's done, remove the face off your JDM unit, switch the bulbs and retain the amber "condoms". After that, it's just reverse order. Good luck!
Old Oct 1, 2003 | 09:34 AM
  #24
JayDM's Avatar
All-Motor Street Car
JayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond reputeJayDM has a reputation beyond repute
Skywalker-although I like all cars...I chose to build my EG6 with only parts made in Japan including JDM (oem) parts...
I am very aware that many of the parts I buy for my car, are not only expensive, but often have no "special" purpose.
It sounds like you have a pretty bad-a$$ car...any pics?
Old Oct 1, 2003 | 10:10 AM
  #25
Skywalker's Avatar
Atheist.
Cool, same here. Except for my exhaust and straight pipes.
To each their own, I was just wondering what the difference was. Often, people change their headlights and taillights which serve no special purpose other than a different look. Nothing wrong with that...unless it makes your car ugly.
Thanx, yeah I have pics....but I'm at work right now and don't have access to them.
Old Oct 1, 2003 | 10:36 AM
  #26
EEK's Avatar
EEK
卐 Walnuts
everything is on the opposite side, and if he has a ek or integra the climate control is carbon fibre unless he didnt buy the type-r version..then its pointless ...to me anyways
Old Oct 8, 2003 | 08:07 PM
  #27
20four7's Avatar
20four7 is an unknown quantity at this point
well guys thanx for all of the advice but i need someone to show me or give me a hand...thanx
Old Oct 9, 2003 | 06:41 AM
  #28
JayDM's Avatar
Let me know 20four7
I'll help
Old Nov 7, 2004 | 02:54 PM
  #29
96Integra's Avatar
REDBETTY
96Integra has disabled reputation
Default Re: installing jdm climate control
I THINK MY EYES ARE SQUINTING AS WE SPEAK. ;-)
Old Nov 7, 2004 | 02:55 PM
  #30
96Integra's Avatar
REDBETTY
JDM!!!!!!!!!!!!!!!!!!!!!
elmer20
Jul 5, 2007 05:01 PM
