idle surge between 1.5k-2k '92 civic
representyoshit
jdm d15b - the car only surges when the throttle is cracked not when pumped, only when trying to give it a little gas.
-iac is bypassed, sensor plugged in. does not affect idle, only on initial start when cold. throws cel #14 - iac
-no vaccum leaks
-tps is good, checked with multimeter and adjusted to specs
i do not think there is a fitv sensor, i have an extra plug that looks like the iac one. i need help, cannot think of anything else to check for. someone has to know whats going on.
-Dustin
-no vaccum leaks
-Dustin
representyoshit
Re: idle surge between 1.5k-2k '92 civic
checked o2 and it needed to be replaced. bought a new one, but the problem is still there. bump........need this resolved, the car feels like its going to fall apart (shaking and vibrating) when it hits this rpm range.
