Honda Brake Question (HELP)
Old Apr 4, 2004 | 12:25 PM
Stillpushin's Avatar
Blow Me
Stillpushin is an unknown quantity at this point
Default Honda Brake Question (HELP)
91 Crx si. When it is hot outside the brakes feel soft almost like the lines are leaking fluid (which they are not). It is weird because the brakes feel solid when it is colder out side. When i pump the pedal it gains pressure. I should probably re-bleed the lines, but why would temperature matter and could it be something else.
Old Apr 4, 2004 | 02:00 PM
Wadman85's Avatar
I heart honda
Wadman85 is an unknown quantity at this point
Default Re: Honda Brake Question (HELP)
bleed it and put new fluid in
Old Apr 4, 2004 | 03:45 PM
_Red_Rocket_'s Avatar
_Red_Rocket_ is an unknown quantity at this point
also you could have a bad master cylinder. i had to replace mine in my crix.
Old Apr 4, 2004 | 04:01 PM
sikkcrx's Avatar
AKA DEATH TRAP
sikkcrx is infamous around these partssikkcrx is infamous around these partssikkcrx is infamous around these partssikkcrx is infamous around these partssikkcrx is infamous around these partssikkcrx is infamous around these partssikkcrx is infamous around these partssikkcrx is infamous around these partssikkcrx is infamous around these partssikkcrx is infamous around these partssikkcrx is infamous around these parts
diddo. i've had 4, 2 had bad master brake cylinders.
Old Apr 4, 2004 | 04:33 PM
Blow Me
But was does the temperature outside have to do with anything?
Old Apr 5, 2004 | 09:11 AM
xexjh09's Avatar
Back in!!
xexjh09 is an unknown quantity at this point
If you tried putting new fluid and a new Clutch master cylinder in it, try replacing the slave cylinder.
Old Apr 5, 2004 | 09:14 AM
xexjh09's Avatar
Back in!!
Should of read the post better... Some reason I thought you were talking about a clutch...
Old Apr 5, 2004 | 10:04 AM
King Dingaling's Avatar
Big Dick Playa
King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling
replace all the lines. the master cylinder the pads the rotors. then you wont have a problem. what it is, is probably your lines have deteriorated from the inside so its not leaking but causing swelling in the lines due to excessive heat therefore your gettin a spongy or soft feelings pedal. so sooner or later the brakes will fade and you will crash. so just do an all new aftermarket system if you have the money. and BTW is your fluid level dropping and if so is there and spots in the system your finding fluid. if not it may be leaking into the brake booster and causing that to go bad
Old Apr 5, 2004 | 10:06 AM
Big Dick Playa
i would think that the outside temperature can affect the lines by causing them to heat up more than need be. there for giving more elasticity to the deterioratic line. thus causing swelling. have you noticed rubber is softer when hott. than when cold? thats the only solution i see?
Old Apr 5, 2004 | 10:38 AM
Blow Me
Awesome, Thanks guys. When i get home after school get out for the summer i will do a complete brake overhaul. Can't go wrong with being too careful about brakes.
goosane
Sep 29, 2008 06:03 PM
WhiteEg6
Aug 8, 2008 05:00 PM
93civicgone
Jun 21, 2007 08:04 AM
Tito
Aug 24, 2006 04:12 PM
LudeDude98
Oct 9, 2003 03:23 PM
