HELP!! engine troubles
Old Jul 20, 2004 | 07:54 PM
93hatch's Avatar
93hatch has disabled reputation
Default HELP!! engine troubles
ok heres the deal i bought a 93 hatch that had a blown timing belt. well i replaced the timing belt but realised it had some bent valves so i went ahead and put a good head on it (with good valves and shit) well i did have the head milled down and all new gaskets...now after about 300 miles on it when i first start it up it smokes..its blue so im assuming its oil. then it clears up..but the motor just bogs down when you take off then after about 2-3 seconds just takes off and runs good. what is it!!?? and can you fix it?
Old Jul 21, 2004 | 05:25 AM
DA-BEAST's Avatar
Function>Form
DA-BEAST is infamous around these partsDA-BEAST is infamous around these partsDA-BEAST is infamous around these partsDA-BEAST is infamous around these partsDA-BEAST is infamous around these partsDA-BEAST is infamous around these partsDA-BEAST is infamous around these partsDA-BEAST is infamous around these partsDA-BEAST is infamous around these partsDA-BEAST is infamous around these partsDA-BEAST is infamous around these parts
Default Re: HELP!! engine troubles
piston rings
Old Jul 21, 2004 | 06:44 AM
Dang Yo's Avatar
Justa lil 6
Dang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the rough
or bad valve stem seals
Old Jul 21, 2004 | 09:17 AM
VT Prix GT 2006's Avatar
Motor Trend Mechanic
VT Prix GT 2006 is an unknown quantity at this point
The last two posts are the 2 things that are most likely causing the problem. Check the valve seals first. It'd suck to have to go in and replace the piston rings only to find out its your valve seals.
Old Jul 21, 2004 | 04:22 PM
93hatch's Avatar
im pretty sure its the rings becuase even when its warmed up and not smoking it still bogs...it bogs then comes on real hard. im lost on this one.. im sick of the whole car thing..i think its time to sell and buy another truck.
Old Jul 25, 2004 | 10:34 AM
PoS hYbRiD's Avatar
Old School Beast
PoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these parts
how much you want for it
Old Jul 25, 2004 | 05:14 PM
ForcedFedTeg's Avatar
loved by all
do a compression check first, its easy and will eliminate certain problem it could be.
hatchblack
Jul 23, 2008 09:45 AM
USElesRyDeR01
Nov 30, 2005 11:14 AM
Dang Yo
Oct 19, 2004 05:52 PM
rat9C1
Aug 11, 2004 03:49 PM
