H22A1 or H23A1?
Old Oct 19, 2006 | 09:08 AM
  #21
Enigma's Avatar
Default Re: H22A1 or H23A1?
Originally Posted by Uh_Dave
The cams also have a lot to do with rod/stoke ratio, The entire motor is designed around that and when you change something as important as a block with different design it does make a difference.
The head makes no difference in the ROD to STROKE ratio.
I don't understand how you can misconstrue this equation.
Cams have alot to do with the air flow of the motor. Tweaking them and the timing will enduce either better gas mileage or more power.
The bottom end has everything to do with rotational mass, and the head has everything to do with air-flow.
Old Oct 20, 2006 | 08:40 AM
  #22
redlineludesi's Avatar
redlineludesi is an unknown quantity at this point
They aren't designed to do the things we do to them. Non vtec blocks and a cam/stroke ratio then the vtec motors, you throw shit off when you do these things. THey will break but the quality of the work and miles on motor changes how long they last.
eh you're right apart from stock yea...
Old Oct 20, 2006 | 08:43 AM
  #23
Originally Posted by Enigma
You just totally contradicted yourself.
Die.
i'm sorry race reliable.. reliable enough to race and last a while doing it...
I'm sorry if it hurt your feelings, you must not know how to tune an engine I guess
Old Oct 20, 2006 | 02:11 PM
  #24
IB4Storm's Avatar
IB4Storm has disabled reputation
Thanx guys Ill keep the H22 thats in it now. Im not boosting it just daily driving for now. When I finish my CRX project im gonna start on the prelude.
Old Oct 20, 2006 | 06:25 PM
  #25
Grease Monkey's Avatar
Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey
My ls/vtec seems pretty strong.
Old Oct 23, 2006 | 04:27 AM
  #26
Enigma's Avatar
Is it the one in the Civic in your sig?
Old Oct 23, 2006 | 05:06 AM
  #27
Yes.
As far as the H22/23 they don't seem to do as well as the more common LS/Vtec. I would just stick with the H22 if I was you. Sell the H23, and use the money to mod the H22.
Old Oct 23, 2006 | 05:12 AM
  #28
Enigma's Avatar
Yes.
Isn't the R/S in the non-vtec H23 worse than that of the vtec version (H22)?
And both worse than that of the B-Series?
Old Oct 23, 2006 | 12:51 PM
  #29
Yes and yes. There are very few H22/23's that have stayed together, and the cost of the aftermarket internals ie rods and pistons are significantly more costly due to HAVING to sleeve the H series in order to run forged pistons.
Old Oct 23, 2006 | 12:56 PM
  #30
Enigma's Avatar
I knew it
The numbers don't lie.
K-Series here I come
