ground problem??
Old Mar 25, 2008 | 01:59 PM
kaltares's Avatar
CustomGSR
kaltares is an unknown quantity at this point
Default Re: ground problem??
Originally Posted by 00si
would that cause the fuse to the ecu under the hood to pop as well
depends on what u hooked the power up to.
Old Mar 25, 2008 | 02:07 PM
00si's Avatar
00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts
the battery was draining i took the alt off to get tested it was not popping the fuse to the ecu before i checked the alt....wtf????
Old Mar 25, 2008 | 02:27 PM
CivicRenModelX's Avatar
CRX
CivicRenModelX has disabled reputation
Did you disconnect the ground before you unhooked everything.
Old Mar 25, 2008 | 05:19 PM
Maybe you should get someone who understands electrical systems to help you out, or this could take a while.
Old Apr 12, 2008 | 12:15 PM
00si's Avatar
please close
Brian T
Jul 30, 2006 01:47 PM
black6gen
Mar 3, 2005 07:03 AM
luckyindychild
Feb 15, 2005 10:19 AM
sintegra
Jul 22, 2004 09:09 PM
