ground problem??
Old Mar 12, 2008 | 08:34 PM
00si's Avatar
00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts
Default ground problem??
i just recently had pod guages installed on my car and my battery went dead i thought it could have just been the battery so i went out and got a new one well now the new is doing the same thing idk whether its the alternator or whether i have a bad....all these problems just started.....i just noticed that the only ground under the hood i see is from the tranny area to the side of where the tranny mount bolts up
Old Mar 12, 2008 | 08:53 PM
Jarrod's Avatar
braap braap
Default Re: ground problem??
Run the car and take the terimnal of the battery. If your car dies, then you have a alt problem(or a wiring problem)
What kind of battery are you buying? Autozone?
What alt are you using? Autozone?
Old Mar 13, 2008 | 01:27 AM
toyota_aristo's Avatar
toyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the rough
Make sure your pods are wired correctly. They could be wired directly to the constant battery voltage and draining it dead. Good luck.
Old Mar 13, 2008 | 08:28 AM
All these problems just started when you installed the gauges. Look there first. Get a multimeter that can read current (the multimeter goes inline between power and the gauge in this case) and see if there is any current draw with the car off. I'm guessing you'll either find a bad gauge or a wiring problem.
Its also possible you've pinched a wire when the pod was installed.
Old Mar 24, 2008 | 05:04 PM
00si's Avatar
i did a lil more checking i took the alternater off and had it tested and i put it back in after i found out that it was still good.....now i get the battery cables on and turn the key over to start and nothing the fuse under the hood for the ecu had blown i replaced it happened again
Old Mar 24, 2008 | 05:09 PM
So you haven't tried to disconnect power to the gauges, and you're still wondering why you're having problems...? I'm sure your alternator and battery are fine, you just have a wiring problem with the gauges I'm willing to bet..
If you just did some electrical work in your car, and now you're having problems, look first at the electrical work you just did.
Old Mar 24, 2008 | 05:18 PM
CivicRenModelX's Avatar
CRX
CivicRenModelX has disabled reputation
Dude sounds like they are hooked up to hot all the time.
Old Mar 24, 2008 | 05:25 PM
thermal's Avatar
TurboPipingSystems
it is most likely from the pod.... disconnect that thing... see what happens... I would've done that first before taking off the alternator... that is too much work compared to disconnecting the pod....
Old Mar 24, 2008 | 05:42 PM
CRX
How did you hook the pod up?
Old Mar 25, 2008 | 01:03 PM
00si's Avatar
would that cause the fuse to the ecu under the hood to pop as well
