Fuel Question
B18C1-T What?
Fuel Question
B18 turbo ok. Lets say 12 pounds to start low boost of course. I dont trust rc injectors web site fully so i just wanted to hear from you guys what size injectors should I use. Keep in mind i have my stock fuel pump and a walbro booster pump 255. thanks guys. I trust experience and hearing what has worked
Re: Fuel Question
it depends on what you're gonna control them with really... if you're just planning on using a FMU setup... then go with 310s... if you want to use the VAFC hack, then use 440s. and of course if you use hondata you can use 440s too.
DESTROYS DONUTS !!
im using 310's and i run 11 psi everyday, cars tuned for 13-14 psi and i still run pretty rich on the 310's, not sure what the duty cycle is cause im running an afc and an fmu, but it seems to be working just fine.......and i thought the HACK was just for vtec motors, if it is than your out of luck if you have an ls.......
