excess oil consumption
Old Nov 15, 2006 | 01:56 PM
G32BTurbo's Avatar
Drag757.com Alumni
G32BTurbo G32BTurbo
Default excess oil consumption
Over the summer I did a minor head overhaul on my mitsubishi including: headgasket replacement, head milling (slight warpage), replacement turbo, and valve stem seal replacement. Now the engine consumes (leaks) about a half a quart of oil every 100 - 200 miles. I see that there is oil around the head and the block where the new headgasket is. What is the problem? Are the head bolts not torqued right? We torqued them to the specs. Is there a proper way to torque the head bolts in addition to following the torque order? Should I do a comression/leak down test? Any info will be useful.
Vehicle: 1988 Mitsubishi Mirage Turbo
Mileage: 93,000
Engine: 1.6L SOHC 8v
Old Nov 15, 2006 | 03:07 PM
MaxPower's Avatar
Default Re: excess oil consumption
Did you buy new studs or reuse the old ones?
Old Nov 16, 2006 | 12:18 PM
G32BTurbo's Avatar
Drag757.com Alumni
G32BTurbo G32BTurbo
reused the old ones
Old Nov 16, 2006 | 01:27 PM
MaxPower's Avatar
Originally Posted by G32BTurbo
reused the old ones
Get some APR, you can torque them tighter and not have to worry about the head lifting at high RPMs since there a stronger grade. That's most likely the problem. Use the torque spec they give you. I believe for my car it was around 60ft lbs on stock studs and with ARP I could go up to 80 - 85lbs.
Also you should re-torque the studs after a couple of heat cycles.
Old Nov 16, 2006 | 01:40 PM
esohsee's Avatar
I'm worse drugged
esohsee has disabled reputation
since you'll have the head off check it for straightness again...
Conceited757
Aug 3, 2006 08:55 AM
b18c1EJcivic
Aug 16, 2005 07:02 PM
