ECU Problem
Old Oct 19, 2006 | 01:13 PM
strtfightncivc2's Avatar
strtfightncivc2 is an unknown quantity at this point
Default ECU Problem
Ok so i was getting a check engine light for a while so i jumped the harness and got code 22 wich is vtec oil pressure and i found the wire and it was just hanging out the ecu...how do i get this wire back into the clip that goes into the harness??? Do i have to sader solder (no idea ho to spell it) to get it back in there let me knwo your opinions thanks
Old Oct 19, 2006 | 01:25 PM
Default Re: ECU Problem
ok the little clip is misisng inside of the big clip....anyone have a clue what to do..can i just pull the vtec wire all the way throught the clip and tie it aroudn the nipple sticking out from the ecu??
Old Oct 20, 2006 | 05:50 AM
kyle h.'s Avatar
fraggle rock
kyle h. will become famous soon enough
you could do a lot of different things. I'd suggest trying to get ahold of some ecu pins and just re-pining that wire.
Old Oct 20, 2006 | 06:45 AM
does anyone know where i can get some ecu pins???
Old Oct 20, 2006 | 07:07 AM
What ECU? I can hook you up with OBD1 Honda pins. You could also splice another wire to the end with a good pin on it.
hatchn1.6
Oct 27, 2008 12:57 PM
Tim-Tim
Want to Buy / Trade ARCHIVE
14
Jan 16, 2008 07:16 PM
1qikcoupe
Mar 21, 2005 06:53 PM
Durrett Syndrom
Mar 17, 2003 04:33 PM
