DSM SMOKING HELP.... :WTF:
WELL YEAH THANKS FOR THE HELP AND I REALLY THINK IS MNY TURBO BECAUSE IT WILL ONLY SMOKE WHEN UNDER HIGH PSI OR ANY BOOST PRESSURE BUT IF I I HAD TEH CAR JUST SITTING THERE AND REVED IT NO SMOKE ONLY WHILE THE TRUBO WAS BOOSTING SO GUESS WHAT IM UPGRADING TO ABOG 16G THIS MONDAY ILL LET YOU GUYS KNOW WHATS UP WITH THAT AND IF THATS NOT THE PROBLEM WELL AT LEAST ILL HAVE A NEW TURBO UPGRADE
THANKS FOR ALL YOUR HELP
Originally Posted by 88CRXHFBSTNG
piston rings are worn out.
common problem on this make of vehicle with high milage.
With that little info why would you try to scare someone with garbage info??
Originally Posted by Ninety7GSX
come on man are you serious??
check the plugs. if it is either the rings or seals. the plugs will be oil fouled and the smoke would be white. and don't be scared.
do a compression test, if that shows a worn out engine do a leakdown test and that will isolate the failing component{s}. most likely th e motor is clapped out or ur turbo is fuct... anyway around it be amazed u got that many miles from a dsm
