dim, pulsing lights, and clutch help
Old Feb 5, 2004 | 10:13 AM
WutupYo's Avatar
GLHF
WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo
Question dim, pulsing lights, and clutch help
when i run my car with the lights on, the headlights and gauge lights kind of pulse with the motor. i was thinking it is the alternator, just not sure...
also... when i let the clutch out, it sticks about a half an inch of the way in when i let off of it, but it is not engaged. then other times it will come all the way out. but i can feel the half an inch of play in it when i just set my foot on the peddle and barely puch, like i can feel the point where the clutch engages and disengages. do i just need to get it adjusted? cuz like i said , it doesnt do it all the time...
and with the lights, it seems like when the car warms up after a while, it stops...
Old Feb 5, 2004 | 05:20 PM
JBub's Avatar
It's Duck Season
JBub JBub JBub JBub JBub JBub JBub JBub JBub JBub JBub
Default Re: dim, pulsing lights, and clutch help
alternator with the dimming lights-
you'll know for sure if your car won't start in a few days or just randomly cuts off.
and the clutch problem is a throwout bearing-
if you're going to replace the bearing, you're also better off getting the clutch and flywheel replaced also. It'll be a lot of hassle just to get the tranny worked on for a bearing replacement.
Old Feb 5, 2004 | 05:22 PM
That's why it always says to use lots of grease in the instructions, I had the same problem with the moving clutch engagement point.
Old Feb 5, 2004 | 05:37 PM
JBub's Avatar
It's Duck Season
If the bearing is still good, then just coat it with white lithium grease, but don't get it all over the clutch, and flywheel surface.
basketthis69
Other ARCHIVE
May 13, 2008 06:53 PM
RaCe_Me_FaSt
Want to Buy / Trade ARCHIVE
Jan 15, 2008 06:37 PM
FastPrelude420
Nov 30, 2006 07:22 PM
