D-series Head HELP
Old Oct 21, 2006 | 09:18 PM
StermeR's Avatar
CTR Coming Soon!
StermeR has a reputation beyond reputeStermeR has a reputation beyond reputeStermeR has a reputation beyond reputeStermeR has a reputation beyond reputeStermeR has a reputation beyond reputeStermeR has a reputation beyond reputeStermeR has a reputation beyond reputeStermeR has a reputation beyond reputeStermeR has a reputation beyond reputeStermeR has a reputation beyond reputeStermeR has a reputation beyond repute
Default D-series Head HELP
okay i have a 7y block i have a stock y8 head only the head, should i just buy this head?
http://cgi.ebay.com/ebaymotors/d16y8...spagenameZWDVW
or should i use the stock one? Will my motor be able to handle the head off of ebay?
Old Oct 21, 2006 | 11:15 PM
Ready Set Go's Avatar
Ready Set Go has disabled reputation
Default Re: D-series Head HELP
youll need the head, head gasket, timing belt ( not sure if y7 and y8 is the same) search on honda tech theres a couples of write ups on it.
Old Oct 22, 2006 | 04:12 PM
CavemanRacing's Avatar
www.CM-R.net
CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing
Your bottom end will be fine with that head. The head is not going to make that much more power than stock if it is staying NA.
Old Oct 23, 2006 | 01:49 PM
kyle h.'s Avatar
fraggle rock
kyle h. will become famous soon enough
the d16y7 block should be the same as the y8 block. so you'd just be building a y8...
Old Oct 25, 2006 | 10:26 PM
JIDM_EG6's Avatar
JIDM_EG6 has disabled reputation
You can def. do it. A buddy of mine put a motor like that together. It wasn't impressive or fast but it ran good. What can i say he was in love with SOHC motors.
Old Oct 26, 2006 | 10:47 AM
www.CM-R.net
You sir are incorrect. Please stop spreading wrong info.
Old Oct 26, 2006 | 01:12 PM
91 Hatch's Avatar
SSSSSVT
91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch 91 Hatch
same timing belt. I think different pistons. Little higher of compression.
Old Oct 27, 2006 | 08:01 AM
StermeR's Avatar
CTR Coming Soon!
The Y7 block is not the same as the Y8 Block.
But yeah im gonna use the Stock Y8 head i have, i need a vtec solenoid though, y8 intake manifold, y8 dizzy, and i need to get it wired for vtec. But im not sure if it is even worth it.
Like power worth it?
SlOw_ReAcTiOn
May 20, 2008 06:46 PM
slowazcivic
Want to Buy / Trade ARCHIVE
Sep 7, 2007 03:18 PM
