Cylinder Head Porting, pics of cross sectioned KA24DE 240sx
Old Feb 22, 2004 | 06:53 PM
  #21
Brssmnky's Avatar
Mr. K's chauffeur
Brssmnky is an unknown quantity at this point
Default Re: Cylinder Head Porting, pics of cross sectioned KA24DE 240sx
Nope, you don't have to repin if you rotate the cam four teeth. Why the 97-98 heads are different is a huge mystery. Why would they change it in a car that had a limited run? I'm curious to see if it had something to do with the KA24DE starting to go in the frontiers back then.
HAHA. hook me up with some of that nissan vtec.
Old Feb 23, 2004 | 05:19 AM
  #22
Greaser's Avatar
Greaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond repute
soon, my TEC III is coming in shortly.
Old Feb 23, 2004 | 09:51 AM
  #23
tryckjävel's Avatar
fun²
tryckjävel is an unknown quantity at this point
April issue of Turbo Magazine covers "head tricks, cam selection and assembly tricks" which also has a nice detail of what a combustion chamber should look like when its done with porting/polishing/bowl work.
w/o getting too far into squish vs. swirl ... i can honestly say the CC's of the head posted before will not work on the street too well. Nice work, but poses a lot of questions as to why bother doing "it" that way?
Old Feb 23, 2004 | 10:11 AM
  #24
TEC's Avatar
TEC
wave or die
TEC is an unknown quantity at this point
Greaser-
I don't know how far you have gotten so far on porting your head, but may I suggest some things. I would remove the lip between the valve throat and the port. Try to smooth that transition out as much as possible. I wouldn't touch the floor at all. I've noticed that it does more to kill air velocity than than help it. I would blend out the casting imperfections in the ports and throat area.
If you want to get tricky, I would try to make the area between the back of the exhaust valve guide and the area between their and the end of the port as smooth as possible. Right now you have an area that will cause some turbulance in the exhaust getting out of the port. You can scuff up that area really well with a rough cut porting bit. Then take some JB Weld and add it to that area of the port. Allow it to fully cure and dry. Then use a very fine porting bit to shape the JB weld and port into a nice long curve. Finish the entire port with a very light sanding to a high polish.
You can also knife edge the port dividers, and D-shape the exhaust ports.
Hope this helps.
I'm anxious to see what you can do with the KA again. I've almost, but given up on the KA. I want more power. I've started a new project with my new 240 and a certain 6 cylinder that I've acquired. If I can get the cash to get it off the ground....heaven help us all.
Rick
Former Freshalloy member
Old Feb 23, 2004 | 12:17 PM
  #25
Greaser's Avatar
i may ditch the ka for a VQ45DE....i need more torque down low.
Old Feb 23, 2004 | 02:31 PM
  #26
sil80er's Avatar
Good Ship Bear
sil80er is an unknown quantity at this point
vq45de...tisk tisk.....
this is close to what you are talking about
http://members.iinet.net.au/~dcollins/silfiniti/
Old Feb 24, 2004 | 04:56 AM
  #27
Greaser's Avatar
all i need is the motor/tranny. im using a TEC III for engine managment. the rest is easy for me.
92hondacivic
Want to Buy / Trade ARCHIVE
Aug 29, 2008 06:02 AM
camelsx
Jan 8, 2008 03:46 AM
GoldenLeg13
Aug 25, 2007 07:52 AM
2.3Liter
Feb 6, 2005 07:20 AM
Woobie
Nov 12, 2003 05:56 AM
