crx dx w/ zc crank sensor help!!!!
Old Jul 15, 2003 | 12:56 PM
Spoonfed's Avatar
Spoonfed is an unknown quantity at this point
Default crx dx w/ zc crank sensor help!!!!
ok i just put in a zc motor in a friends dx crx. the only code its throwing is the 4 short flashes, which is the crank angle sensor. i already tried crossing the 2 wires over, reseting the ecu both times. i also switched out the sensor and put in one that i know was good. the problem is that when you step on the gas, it bogs reving up and it wont let me past 4,000 rpms. and input would be greatly appreciated
Old Jul 15, 2003 | 01:39 PM
Bert's Avatar
hybrid no more :(
which distributor and ecu are you using? I've seen some zc comes w/ a distributor w/ only 2 sensor on them and doesn't have the third sensor...most mpfi ecus need 3 sensor on them...
Old Jul 15, 2003 | 01:47 PM
Spoonfed's Avatar
is distributor came with the motor so im guessing its the zc and the ecu is the crx si computer
Old Jul 15, 2003 | 01:55 PM
Bert's Avatar
hybrid no more :(
count the wires on the distributor...make sure there are 2 plugs..one plug has 2 wires, one black/yellow and other blue...the 2nd plug should have 6-7 wires(i forget of the top of my head)...3 sensors that have 2 wires each and one white wire....
Old Jul 15, 2003 | 02:02 PM
Spoonfed's Avatar
the second one if i recall has 5 wires.
Spoonfed's Avatar
that plug has one pin slot empty
Old Jul 15, 2003 | 02:29 PM
Bert's Avatar
hybrid no more :(
you need to get a 88-89 teg distributor...there might be a way to rig up that sensor so that you can fool the ecu. I wouldn't though, i would rather get a 88-89 teg disitributor...to be honest i am also not entirly sure if this is the correct fix...i would more say i am 50% sure...
2kSi
Dec 16, 2008 03:02 PM
todb84
Jun 30, 2004 05:21 AM
todb84
Jun 17, 2004 08:16 AM
89lxbill
Mar 3, 2004 11:51 AM
